New Website
the 35 and 41 will both retain the same running surface as their predecessors the only difference is the molded European transom on the back which does not affect the running surface or engine setback because of the length of the previous "bolt on" engine bracket. the 38/41 was built as wider than the 33 however both boats having their hull sides raised will be squeezing out a little extra width. As for the weight of our new build process I'll be able to answer that for you in the upcoming weeks. any other questions feel free to ask away.
