Aluminum cyl head question????
I HAVE CANNFIELD ALUMINUM HEADS ON MY 540s. JUST HAD THEM REDONE WITH NEW GUIDES ON BOTH SETS,VALVE JOB ETC. BOAT WENT GREAT AT THE BEGINNING OF THE YEAR AND HAS SLIGHTY FELL OFF ON TOP SPEED. I DID A COMPRESSION TEST AND LEAKDOWN TESTON BOTH MOTORS ONLY TO FIND I HAVE 7 WEAK CYLS BETWEEN THE TWO MOTORS. ALL LEAKING OUT EXHAUST VALVES. QUESTION IS ARE THE EXHAUST GUIDES PUSHED THROUGH WATERPORTS? IT LOOKS ALL WET AROUND THE BOTTOM OF THE GUIDE THAT STICKS INTO THE EXHAUST PORT.
Inconel valves can tulip also.
What did you have timing set at? Considering both engines are showing issues, Im gonna rule out exhaust problems, cracked head, etc. .
I believe your heads have the guides thru the water jacket, but not sure with a canfield head.
Yes they do!!!! I had inconel tulip this summer......got lucky it didn't break....
