300X AMT vs. 2.5 30 Spectre >
Old 10-23-2012 | 11:27 AM
Default 300X AMT vs. 2.5 30 Spectre
Looking at 2 boats
Spectre
2002 2.5 Absolutely mint in every way...hour meters read around 420 which seems way off given the condition... owner says ecus show 235hrs (he's second owner) Powerheads were rebuilt at Merc about 110 Hours ago not sure if I am comfortable because of the hours Freshwater Boat locally owned have know owner for years great guy
AMT
2005 300x 135 Hours on Motors Unknown on hull looks pretty clean from pics located clear across country ($5k to get home) Saltwater boat (garage kept)
I like both boats and both are in same ballpark money wise I am sure this topic has been covered here just looking for opinions as I have never owned an outboard cat...
Thanks In Advance
SLINGSHOT is offline
Old 10-23-2012 | 11:48 AM
glassdave's Avatar
Neno the mind boggler
Man thats a tough one. Sorry i cant give any technical help but the AMT we raced was one of the funnest hulls i have ever ran. Handled VERY well and for a thirty footer ran rough water pretty good. Seemed if ya just let 'er eat she would go. The AMT sounds like a better deal because of the year and power but unless you can fly out west to see it i am always leery of salt boats.
On a side note the one we raced was a 2.5 boat and i am not sure what the bigger motors would do to the handling. I always thought Deans was a bit on the light side so a bit more weight wouldnt be a bad thing as long as it was balanced out.
08 OPA High Points Champion
glassdave is offline
Old 10-23-2012 | 02:38 PM
Any pics of the Spectre. I would like to see if I recognize it. I should have rigged it
obrien is offline
Old 10-23-2012 | 02:40 PM
sorry i do not
Old 10-23-2012 | 03:48 PM
ziemer's Avatar
If the 2.5's have 110 hours on them, they are either due or just about due for rebuilds.
Depending on what was done on the first re-build...were they re-plated? New pistons? bearings? etc. If only rings were done, costs could go way up this time.
Re-ring only can be a couple thousand per side, whereas full re-builds will be in the $5k-$6k each.
ziemer is offline
Old 10-24-2012 | 10:20 AM
berns29scarab's Avatar
i had a 98 30 spectre w 2003 300x's and a close friend had a late model AMT also w 300x's and they were very VERY similar altho the spectre was slightly faster. Conservative setup, motors deep, 15x32 3 blades labbed ran 107 ...cruising speed was 78 (when the hull packed air) and the X's were VERY thirsty.
berns29scarab is offline
Old 10-24-2012 | 10:45 AM
Aren't the 2.5's more of a race engine? If he's going to be putting substantial hours on the boat, wouldn't he be better off with 300X's?
Mastercraft240 is offline
Old 10-24-2012 | 11:07 AM
If this is the AMT you are talking about:
http://www.offshoreonly.com/classifi...o39990-en.html
The boat is MINT!!!
And no worries about it being in salt water, I doubt you will find any signs of salt anywhere
I don't know anything about the Spectre you are looking at, but I would love to have that AMT
blkmtrfan is offline
Old 10-24-2012 | 11:10 AM
TeamSaris's Avatar
Driver-441
Racer
You cant beat 2.5s for punch and power to weight...id go spectre
TeamSaris is offline
Old 10-24-2012 | 12:30 PM
The boat is MINT!!!
yes thats it.... I'm leaning that way...nice guy seems legit
