B1 Prop hubs >
B1 Prop hubs
B1 Prop hubs
Old 10-23-2012 | 02:37 PM
Default B1 Prop hubs
Should the hubs on B1 props be welded in? If so, why? Added strength? Thanks.
eichhoma is offline
Old 10-23-2012 | 07:43 PM
If you are using a solid hub, I would see no benefit in doing so.
ACrooks69 is offline
Old 10-29-2012 | 08:21 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Square bore FloTorq 2 hub kits do not require welding.
They can't go anywhere.
The actual casting you have may determine a different response.
Brett
[email protected]
bbladesprops is offline
Old 10-30-2012 | 10:19 AM
Thanks Brett, I appreciate your response. They are actually 4 blade 28 P B1's that you labbed up for me 2 years ago... I need to send them back to you to get touched up though and I sure could use a spare set! Thanks - Mark
eichhoma is offline
Old 10-30-2012 | 05:52 PM
Smile
No problem. I'm sure your hubs are fine. Once the prop nut is tightened, the whole assembly is one package that can not move.
Send them anytime for touch up and I'll call you to discuss them.
Brett
[email protected]
Old 10-31-2012 | 11:01 AM
Will do, thank you.
Mark
eichhoma is offline
