fuel tanks 31 bullet? >
Old 10-24-2012, 06:54 AM
Default fuel tanks 31 bullet?
Could use some help im restoring a 88 Bullet wondering if anyone has pulled out the tanks on one. Any imput would be great thanks.
2manyprojcts is offline
Old 10-24-2012, 12:29 PM
VP of the tickfaw200
pulled the floor up to inspect my tanks witch they were in good shape think god. looks to be a esay job just have to remove the foam around them and empty all the gas out.
caseyh is offline
Old 10-24-2012, 04:23 PM
I was looking at it and it looks like they wont fit through the floor pannel will they? and if so it also looks like I have to remove the dash sections is that right?
Old 10-24-2012, 07:03 PM
Yes the foot rest under the helm comes off by its self and the whole console on the other side is one pice. Don't have a pic with the pice off under the helm Or the floor out ill try and get some. It's simple to do
caseyh is offline
Old 10-26-2012, 07:39 AM
Thanks caseyh but I looked at mine and the foot rest is molded into the helm and in the upper right corner of the helm thats molded into the top deck. Its weird most of it is bolted on and some is molded in. I wish there was a way to inspect and clean the tanks with out pulling them. I was hoping not to have to do fiber glass work.
Old 11-09-2012, 06:36 AM
pulled tanks, both helm floor panels removable (screws and caulking held in place), tanks held in w 4 plates and foam each tank, removed as much foam as possible, remove steering wheel, cut away a small corner of aft floor with no structural effect, mechanic Left attached to hoist over night w pressure and tanks pulled loose from foam.
Cree is offline
Old 11-12-2012, 12:27 PM
tanks ok?
caseyh is offline
