Painting k plan help
Old 10-24-2012 | 09:33 PM
VP of the tickfaw200
Default Painting k plan help
Going to blast and re paint my k plans, what type of paint to use?
caseyh is offline
Old 10-24-2012 | 11:24 PM
glassdave's Avatar
Neno the mind boggler
imron or ppg's single stage concept.
08 OPA High Points Champion
glassdave is offline
Old 10-24-2012 | 11:38 PM
But you need to prime with ppg dp 90 first..
FIXX is offline
Old 10-25-2012 | 12:04 AM
What about the bottom.? What creates less drag to give more speed? Should you leave it orange peelyor wet sand it smooth with 800 or buff it or what.?
mcprodesign is offline
Old 10-25-2012 | 01:53 AM
Default fixx
it really does not matter,,drag is drag when the tabs are down..when i paint them i will dp 90 them and wet sand then with 400 then spray them.with imron it goes on like glass and i never get any orange peal..
FIXX is offline
Old 10-25-2012 | 07:13 AM
I shot mine with Concept over epoxy primer.
THRILLSEEKER is offline
Old 10-25-2012 | 05:18 PM
any surface that is wetted creates drag. Even if the k planes are level with the bottom of the boat for stability. My question is does the orange peel make it less drag or does it make it more drag. Because my stock ones have a lot of orange peel. Why would they make them with orange peel if they created drag that way. Just curious
Old 10-25-2012 | 07:54 PM
Maybe they should start building stepped K-Planes.
Old 10-26-2012 | 01:30 AM
Fenderjack's Avatar
Pirate of the Chesapeake
I would opt to have them powder coated. 10 times more durable then paint. JMO
John jr
Fenderjack is offline
Old 10-26-2012 | 06:46 AM
rchevelle71's Avatar
John jr
And 10x more difficult to touch up.
rchevelle71 is offline
