One K-plane is slower than the other >
Old 07-14-2002 | 09:08 PM
blackhawk
Default One K-plane is slower than the other
Had my boat out for the 1st time this weekend(finally) and my port K-plane is slower than my starboard one. It is very minimal(about 3/8" off from down to up) but is noticeable when driving. I did the obvious and checked the oil and it was fine. It was fine before I put it away last year. Cylinder and lines do not seem to be leaking at all. Any ideas?
Old 07-14-2002 | 09:29 PM
Audiofn's Avatar
Charter Member #232
They can get that way when they get older. It may get faster with a little use or it may stay the same. Wish I had better news for ya
Jon
Put your best foot forward!
Audiofn is offline
Old 07-14-2002 | 09:38 PM
blackhawk
I am going to go out one more time and hope it works itself out. The planes were off all winter so I may have a tiny bit of air in the lines. If it doesn't get better I am going to try switching the cylinders to see if it's the pump or the cylinder, at least that way I can trace it better.
Old 07-14-2002 | 09:48 PM
C_Spray's Avatar
Diamond Member #001
Default Trust me....
If you do get them to move at exactly the same rate, it won't last for long. I've actually considered putting adjustable jets in mine to try and keep them the same. Goes for drives, too.
C_Spray is offline
Old 07-14-2002 | 10:02 PM
blackhawk
Mine have always operated at the same speed. At least close enough to where I didn't notice while driving.
Old 07-14-2002 | 10:16 PM
Blackhawk...what does the fliud look like in your pump? Also what kind of pumps do you have? I had this problem also, I had to tear apart the pump clean out a lot of nasty chit flush out all the hydraulic lines then put it all back together and it worked fine. Also if you do one pump you might as well go ahead and do both of them. Hope this helps
THRILLSEEKER is offline
Old 07-15-2002 | 11:29 AM
blackhawk
Fluid looks great. It actually seems to be a slow selenoid. I was playing with it more last night and they seem to be moving at the same speed. The port one just STARTS moving later. I am going to get someone to watch the planes and jump the selenoids to make sure.
Old 07-15-2002 | 12:29 PM
Iggy's Avatar
Someone posted a while back with a similar problem.
A member wrote back asking if the hydraulic lines going to each tab were the same length. Seems that if they aren't, it's possible for them to move at different speeds.
Might be someting to look into.
Iggy is offline
Old 07-16-2002 | 09:35 AM
blackhawk
Okay, here's what I have checked:
Fluid levels, full and equal
Condition of fluid, good
K-plane "hinge" for movement, okay
Length of lines are equal
The selenoids are both working at the same time, the port K-plane is moving just a little slower. This irritates the hell out of me because they have worked fine for 2 years and worked fine when I stored the boat last year.
The only other thing I can think of, besides a weak pump or cylinder, is lower voltage at the port pump. Either befor or after the selenoid. I am going to take a volt meter to it and check it tonight.
Any other ideas?
Old 07-16-2002 | 09:58 AM
blackhawk...listen to the solenoids on both pumps when you raise and lower the planes. Do they sound the same? Do the pumps make any kind of a different noise while they are traveling up or down? If one solenoid makes a different noise the solenoid may be weak or it is having to work harder to raise and lower the plane. I took my hoses loose on the plane cylinders and manually lifted and lowered each plane to make sure that one was not harder than the other thus causing one pump to work harder. let me know what ya find out.
