procharger pulley change question >
Old 11-05-2012 | 12:47 PM
Default procharger pulley change question
I currently running a 502 EFI with a M1SC, I'm considering changing the pulley from a 4.25 to 4.0. Should I plan on gettnig the ECM re-programmed? and any idea of what type of boost increase I will see?
Below are the numbers from last dyno pull:
rpm: 5200
hp: 709
oil pressure: 81.7
fuel pressure: 73.9
thanks
tylogan11 is offline
Old 11-05-2012 | 06:37 PM
More air will need more fuel .
Jeff P31 is offline
Old 11-05-2012 | 06:39 PM
articfriends's Avatar
What year ecu/mefi do you have?
articfriends is offline
Old 11-05-2012 | 07:53 PM
Turbojack's Avatar
What boost was that at? i would say you will need to change the program on the ecm. i would also check and make sure you are under the max rpm of the procharger
Turbojack is offline
Old 11-06-2012 | 07:39 AM
1996 ECM and running between 4-5lbs of boost. Motor was freshened up 2 years ago.
Old 11-06-2012 | 02:39 PM
DesertRage's Avatar
I think ArticFriends asked the magic question. A 1996 is probably a MEFI 1 and I don't believe they recognize boost (no boost compensation table). So, fuel is controlled only by rpm at anything over 100kpa. A MEFI 3 would be a great upgrade for tunability.
DesertRage is offline
Old 11-06-2012 | 06:11 PM
GPM
rpm: 5200
hp: 709
oil pressure: 81.7
fuel pressure: 73.9
thanks
How far did you pull to, max RPM ?
GPM is offline
Old 11-06-2012 | 07:12 PM
Turbojack's Avatar
You got some good HP for that boost. If the ecm is set up for the stock motor I think you will need to do some reprograming if you go for more boost.
Old 11-06-2012 | 07:37 PM
are you running the stock 48# injectors at 74# of rail pressure?
tunertech is offline
Old 11-07-2012 | 08:26 AM
thats a lot of HP for that setup....unless this is like passtime and not being told everything...
ezstriper is offline
