Paging Sydways or WD hitch experts
Is this a good choice for a WD hitch?
http://www.etrailer.com/Weight-Distr...e/RP66130.html
and can you back up with a WD hitch??
Let it rip. That will be fine. You will probably need to buy a "pole tongue adapter" to apply the system to your trailer. ETrailer sells them.
http://www.offshoreonly.com/forums/g...vy+hitch+balls
You can back up just fine, but tight turns may create a bind, forward or backward. Not a big deal though.
You will probably want to release the tension on the bars prior to launching. I usually loosened or removed them before launching, and cinched them back up after retrieving. You don't want the bars to lift weight off the rear of the truck once the boat is off the trailer.
I don't know what your truck is, but a WD hitch does not make up for lack of truck.
Most of the ClassIII hitches that say something like 8500 lbs weight carrying and 14000 weight distributing... Are JUNK!!! Especially GM tube hitches and the Ford "V-5" hitch. V5 is the NAME of it, not the CLASS. If you are at or near your truck's capacity, junk the factory hitch and go with a true Class V hitch from Reese or Curt, or another. Ditch the grade 5 bolts they ship with, and upgrade to Grade 8 bolts. This only costs $300 bucks or so and is worth every penny. So are rear airbags.
I have that exact set up and love it. This particuliar set up is designed to limit sway with the indent in the torsion bars. When you make a turn the bar rolls over the support and then returns back to the indent position when you straighten out. Excellent design and setup. Backing up is no problem.
When making a sharp turn, you will notice the sound of the bars rolling off and on the support.
Member of the Liquid Jungle
If so, I agree. Go back down to a stock tire diameter or maybe slightly larger; go to 18" diameter wheels (nothing bigger than 20)--at least 8 or 9 inch wide and tires that match--E-rated of course. Make sure you check the weight ratings on the tires AND the wheels.
You will see a drastic improvement over stock setup; guaranteed.
