Plugs for HP500efi >
Plugs for HP500efi
Plugs for HP500efi
Old 07-15-2002 | 03:06 PM
Default Plugs for HP500efi
How often should the spark plugs in the HP500efi be changed. Also, I heard that Merc how suggests NGK BR6FS Vs AC MR43T, is this true?
39 Unlimited is offline
Old 07-15-2002 | 03:31 PM
boatinbill's Avatar
Registered User
Yes they did change the recommended plug to the NGK.
I have changed mine twice in a 150 hours. FIrst time to correct a fouling problem, second time because of the changed plug recommendation.
boatinbill is offline
Old 07-16-2002 | 12:22 AM
SteveDavid's Avatar
Charter Member #1093
Nordic Gary,
The answer depends on the type of boating you do. If most of your time is at cruising speeds, say anything above 2800 RPM you probably can get away with 100 plus hours befor changing. On the other hand, if you do a alot of idling, you may be looking at 50 to 75 hours. A couple of indicators are decreased performance, rough idle, cough on acceleration or mis fire.
I have found no difference in performance or livability between the A/C, Champions or NGKs.
Good luck, have fun.
Steve
SteveDavid is offline
Hydrolift
0
05-21-2006 09:09 AM
dhlaw
1
03-17-2006 07:48 AM
Bubbletop409
6
10-12-2005 07:23 AM
Canada Jeff
27
01-05-2004 12:07 AM
Dono
2
10-22-2003 01:09 AM
