out drive   paint  ? >
out drive paint ?
out drive paint ?
Old 11-13-2012 | 04:17 PM
26sonic's Avatar
Default out drive paint ?
are there any durable out drive spray paints can resist corrosion and brackish water ?
26sonic is offline
Old 11-13-2012 | 04:20 PM
Default fixx
sorry but no! not enough solids,,need to paint with imron ...if you have bare alunimum then you need to prime with ppg dp90 epoxy primer.
FIXX is offline
Old 11-13-2012 | 04:47 PM
^^^ what he said. A good epoxy or etch primer on the aluminum and Imron. Last I checked PPG is the OEM supplier for Merc, they have a nice system too. Call around to some body shop jobbers. If your looking to touch up the skegs just buy the Merc aerosol can.
POWERPLAY J is offline
Old 11-14-2012 | 02:35 PM
GO4BROKE's Avatar
I cleaned up the corrosion, primed with a zinc chromate primer, then used the merc rattle can. Holds up fairly well.
[img][/img]
GO4BROKE is offline
Old 11-15-2012 | 02:00 PM
26sonic's Avatar
go4broke after using the zinc primer , how long did you wait before painting and how many coats of paint did you put on ? did you use sand paper before priming ? and what grit ?
26sonic is offline
