Will my 2001 GMC 2500 8.1l 496 handle 87 octane? >
Old 11-13-2012 | 09:06 PM
Default Will my 2001 GMC 2500 8.1l 496 handle 87 octane?
I was thinking today as I was filling up the tank on my 2001 GMC 2500 with an 8.1L 496, I use 93 octane just to stay on the safe side. My question is this, is 87 octane safe to use on my truck? I find it pointless to keep putting 93 octane if I can get away with 87 and get more for my money.
272bajadriver is offline
Old 11-13-2012 | 09:17 PM
Use 87 in all of our GMs. 6.0, 5.3 and our V10 in the Excursion. They tow all over the US. Never had a problem.
Ultra Boats MW is offline
Old 11-13-2012 | 09:21 PM
i have the same truck 2001 8.1 496 with allison trans .never seen anything but 87 . mileage is terrible think i get about 11 mpg pulling a 11.000 lb boat or empty driving to work
smokin' gun is offline
Old 11-13-2012 | 09:46 PM
Wow and this entire time I've been putting 93 and just throwing money away. Smokin gun your right the truck gets bad gas mileage but it's an awesome truck!!! It has plenty of power and rides aweomse, I absolutely love mine. From now on 87 it is.
Old 11-13-2012 | 10:18 PM
I have the same truck too 2001 2500 hd 496 Allison have only ever ran 87, did you see in the manual or something to run 93? Ive never actually checked.
pullmytrigger is offline
Old 11-13-2012 | 10:30 PM
Fenderjack's Avatar
Pirate of the Chesapeake
Yes you will be fine, however with lower rated octane you normally get worse gas mileage.
John jr
Fenderjack is offline
Old 11-13-2012 | 11:07 PM
Mine did not have a manual, seems a lot of people on here have the same truck and I can see why it's a great truck!!
Old 11-13-2012 | 11:25 PM
Virtually all modern vehicles can run 87. These vehicles have knock sensors. If you are getting pre-combustion because of lower octane the computer will adjust the timing to compensate. I had a Corvette, owners manual said premium fuel only, I could not tell a difference in power between 92-93 or 87, so I ran 87. No problems.
ondtip is offline
Old 11-14-2012 | 12:08 AM
Default fixx
yes it will run with it but,,,,with 93 octane it burns slower and in return you will bet more mpg,the 87 octane will burn faster and hotter...i use to burn 93 and i went to midgrade..
FIXX is offline
Old 11-14-2012 | 01:53 AM
Fenderjack's Avatar
Octane rate is for the rate at which the fuel is prone to detonation. The higher the rating the less prone to detonation, more of a proper, complete burn. The knock sensors are to pick up just that, when that happens it cuts timing, in turn making a less efficiante burn, can def hurt gas mileage ESP if you are towing something.
John jr
