Anyone know what a 420 HP Mercruiser oil pan looks like 1988? >
Old 11-15-2012 | 01:17 AM
Default Anyone know what a 420 HP Mercruiser oil pan looks like 1988?
cyrus77 is offline
Old 11-15-2012 | 05:49 PM
i think its just a 7qt. if your puting a new one on you best to go with at least a 14qt gil marine
frontseatdriver is offline
Old 11-15-2012 | 11:07 PM
perfspec's Avatar
Good advice!
perfspec is offline
Old 11-16-2012 | 12:39 AM
Were they cast or stamped steel. DId they have a trap door in 1987?
cyrus77 is offline
Old 11-16-2012 | 03:12 AM
why does a 420 need a 14 qt pan?
mike tkach is offline
Old 11-16-2012 | 04:24 AM
they were stamped steel no trap door but do have a windage tray . i have about 4 of em need 1 ???
smokin' gun is offline
Old 11-16-2012 | 06:01 AM
A 14 quart pan on a 420 is a complete waste of money. The stock pan will work just fine.
endeavour32 is offline
Old 11-17-2012 | 05:56 PM
if your running the boat hard in the ruff stuff you want to keep the oil in the bottom of the pan and seven more qts is a good thing. also with a gil pan it has a scrapper bilt into the baffle which keeps oil from winding around the crank and helps with windage .especially if your running over 5500 rpms.but if your not hard core a 7 qt pans fine but still recomend a cooler.
Old 11-17-2012 | 06:23 PM
My oil pan on 88 420's had the trap door ... I reused them and went with a 2 qt oil filter wix racing 51734r
TylerBurich is offline
Old 11-23-2012 | 04:00 PM
My Merc 400's have the `14 qt pans. I think ANY high performnce offshore boat should have them.
Wannabe
wannabe is offline
