gel coats
Old 07-15-2002 | 07:41 PM
PANTERA LOVER
Default gel coats
who is the best gel coat repair man for nicks and scratches on a boat in miami???
-any ideas?
-PANTERA LOVER
Old 07-16-2002 | 09:04 PM
GaryMMM
Call Thomas Williams at 305-947-1312 for the fiberglass. GaryM
Old 07-17-2002 | 09:01 AM
PANTERA LOVER
GaryMMM,
Thanks for all the suggestions, this really helped me out.
-PL
Old 07-17-2002 | 11:42 PM
shu-dog's Avatar
Default Nicks and Scratches
Hey Pantera Lover. If you're handy and know how to use some tools,ie a high speed buffer then I would recomend you do it yourself. That is if money is an issue. If not then disregaurd the rest.
I had alot of salt water deposits and tried just about every type of car polish and cleaner out there. Finally took it too a pro and talked it over. My new friend simply said to save my $300 and do it myself. I bought an adjustable buffer/polisher/sander. Its available at Home Depots for around $150-175. You need adjustable rpm speeds from 1500-3500. Then I bought some of his professional grade polish and and a cleaner/rubbing compound. Just took it slow and actually did it a couple of times. Turned out great. Also I now have a buffer to work on my boat for waxing and the custom truck and other toys. A total time saver. Anyway just my two cents.
Shu
shu-dog is offline
Old 07-18-2002 | 08:59 AM
PANTERA LOVER
Cool
that sounds like a good idea, my issue is i actually have some "chips" i guess you could call them in the side that go a little deeper, would that also work for that or make it worse??
-thanks
-PL
Old 07-18-2002 | 08:49 PM
GaryMMM
If you want to do it yourself, fill the chips with SeaFit Gel Coat Quick Fix. It comes in a few colors and does not require mixing. Fill the chip, smooth the patch and let it dry. Rough sand the patch smooth and then polish it to a shire like in the last message. Good luck, GaryM
RaggedEdge
Detailing, Painting, & Fiberglass
19
09-20-2008 04:40 PM
DKerns
8
03-23-2007 09:44 PM
US1 Fountain
10
04-28-2004 06:46 AM
dyno
02-04-2004 02:40 PM
Pure Energy
02-21-2003 07:05 AM
