running fuel injected motor on stand. >
Old 11-16-2012 | 09:54 AM
Default running fuel injected motor on stand.
I recently removed A 350 mag mpi from my boat with a problem replaced cylinder heads and oil pan leaking. What do I need to do to run this on the ground to set timing and check for leaks before putting engine back in.
BIGMC69 is offline
