502 compression in lbs ??? >
Old 07-15-2002 | 11:04 PM
stevejohns
Default 502 compression in lbs ???
What should the comp be? I tested mine with a decent tester engine was cold and not run for about 2 weeks. Alt was 2000 feet. lbs ran from 128 to 136. How does that sound?
thanks sj
Old 07-16-2002 | 04:21 AM
Compression test should be done with the engine warmed up---oil at operating temperature to get a real accurate reading. The numbers would probably go up some if the engine was warm. The numbers are not BAD just slightly low. I think Merc says they should be at around 140-145 with a 10 lb variance maximum between cylinders.
Griff is offline
Old 07-16-2002 | 09:50 AM
stevejohns
OK thanks. I was changing the manifolds and couldnt fire it up to get to a warm and oiled state. Looks like im ok.
I did some quick and crude math , my boat has 160 hours on it. Compared to highway speeds and rpm it has about 18,000 miles on it. Not bad for 10 years old
Old 07-16-2002 | 10:28 AM
Kokopelli's Avatar
With 50 hrs on mine it tested at 165 -170 after warmed up.
Kokopelli is offline
Old 07-16-2002 | 08:12 PM
MACDAD260's Avatar
Charter Member #818
After 20 hours mine tested 155-160 cold.
MACDAD260 is offline
Old 07-16-2002 | 08:19 PM
mopower's Avatar
Toxic FORMULA
Stevejohns, You must have been running the hell out of that poor boat since I heard SK. has a boating season about three weeks long
Math...160 hrs divided by 10 years= 16hrs a year. With a three week boating season you must really be busyLOL.
mopower is offline
Old 07-17-2002 | 02:01 AM
stevejohns
3 weeks????????? maybe if we scrape the snow off during week 1 and 3 !!!!!
rmcdade
5
10-07-2008 08:35 PM
Smitty
11
09-03-2008 08:00 AM
xhere
14
11-08-2006 10:43 AM
vandeano
7
06-30-2005 12:09 PM
26ZX Donzi
9
04-25-2002 12:10 PM
