Hitch
Old 11-22-2012 | 07:50 PM
jmackin's Avatar
Default Hitch
Best place to find the heavy duty hitch? The adjustable kind with multiple size balls, etc..
jmackin is offline
Old 11-23-2012 | 03:08 PM
http://www.turnoverball.com/products...receiver-hitch
That is what I have, I bought mine new in 07 and have no problems at all. I take it on and off each time I use it, still looks new.
Beachbum28 is offline
Old 11-23-2012 | 04:02 PM
Check etrailer.com
Wannabe
wannabe is offline
Old 11-23-2012 | 04:10 PM
jmackin's Avatar
Thanks but need something heavier, only rated for 10k lbs.
jmackin is offline
Old 11-23-2012 | 04:46 PM
http://www.cabelas.com/product/OneMo...h-All+Products
This is what I bought. Original OneMount.
BGIII is offline
Old 11-24-2012 | 03:43 PM
jmackin's Avatar
Perfect and price is reasonable too. Thanks!
jmackin is offline
Old 11-26-2012 | 02:45 PM
How heavy are you looking for?
I have not seen any rated for more than 10k.
DiversiTech does have a higher tongue rating at 1,500 http://www.diversi-tech.net/Hitches%20Page.htm
I figure if the weight it close and the drop hitch is not being fully extended there is little problem. From a conversation with the mfg, hitch parts must pass tests at maximum extension of three times their rated weight.
If weights are significantly greater or frequent / longer distances are planned, a solid hitch with the proper ball and height is better IMO. There is less hitch slop yeilding a solid pull which is better at higher weights.
Curt's forged ball mounts are some of the heaviest I have seen. A heavy tongue weight will usually sag the rear so it is important to take this into account when selecting drop.
http://www.curtmfg.com/Category/168/...0Ball%20Mounts
Make sure a properly rated ball is used as well.
ChargeIt is offline
Old 11-26-2012 | 07:01 PM
I have the Diversi-Tech..expensive and a piece of junk.. ball rusted in less than a year.. the B&W is so much better
ICDEDPPL is offline
Old 11-26-2012 | 08:39 PM
Cap-N-Grumpy's Avatar
Post #5
Cap-N-Grumpy is offline
Old 11-26-2012 | 09:43 PM
Plum_Crazy's Avatar
There is also the Anderson Mfg. EZ HD hitch rated at 14,000lbs. It's the only one I found that would work with Rock Tamer hitch-mounted flaps.
http://www.andersenhitches.com/Catalog/ez-hitch.aspx
Plum_Crazy is offline
