mechanical trim indicator part needed... >
Old 11-24-2012 | 09:36 AM
Default mechanical trim indicator part needed...
I had a mechanical trim indicator given to me. Problem is it doesn't have the cylinder shaped part that bolts on the rod that goes through the hydraulic rams. Anyone have one? If I can make one on a lyhte are they made out of aluminum or stainless?
stlliberator is offline
Old 11-24-2012 | 10:05 AM
97FASTech's Avatar
Veteran: Army
Don't have the part, but this should give you an idea how to make one or purchase:
97FASTech is offline
Old 11-24-2012 | 11:49 AM
Yes I need part 5....thanks
Old 11-24-2012 | 12:22 PM
c_deezy's Avatar
Stainless, unless you use pretty thick aluminum.
The 'cup' is usually just a piece of stainless tube with a plate tack welded into one end. Probably cheaper going that route than machining a 2" chunk of stainless stock.
Worst case you could make one out of mild steel and paint it to use until you find one in stainless.
c_deezy is offline
Old 11-24-2012 | 01:07 PM
97FASTech's Avatar
Veteran: Army
Did you check with Black Baja, maybe he has this part. You were working with him on the hatches.
Old 11-24-2012 | 05:13 PM
This is a aftermarket part..these are add on mechanical trim indicators
