Freshwater Pump
2002 342 Baja. The pump located under the step going down into the cabin. I am thinking this is the freshwater pump for the head and sink. Am I correct? If not, what is that pump for?
Thanks! I cannot pump water out of the washdown you refer to at the rear, nor the head or sink. You can hear the pump turn on after flipping the switch on the panel but the water pressure switch keeps tripping. Thought maybe that pump might be bad. The forward bilge got flooded after a hard rain.
there is a forward Bilge pump is under the step. thats AUTO only. (you can lift the lid/one steps top up and see this)
there is a SUMP pump behind that box/area (the whole step/lid) come out as one peice, and you will see the shower sump pump, and the vacuum generator (if you have vacuflush.)
the freshwater pump, is under the passenger side cockpit floor. right in front of the tank (tank-filter-pump)
