WANTED 2 ANSON Turbosystems knock gauge >
Old 12-03-2012 | 01:19 PM
Default WANTED 2 ANSON Turbosystems knock gauge
HI
I am looking for 2 Anson Turbosystem engine knock meters or equivelent?
It seems theey may have gone out of bussiness?
Any suggestions on where to buy a set would be helpful
Thanks Bruce
Bruce is offline
Old 12-03-2012 | 02:02 PM
Rookie's Avatar
I can't find anything for them either. I am thinking of using an existing knock module off a TBV or a GM knock module. I will hookup the knock sensor and when the module senses knock from the sensor I will use that signaled 8v-12v sourced from the module to source ground (-) off of a relay to my ignition. This will then pull the preset timing retard out. I assume you have Crane Hi-6m's also. I have schematics of my system on my home computer.
Rookie is offline
Old 12-03-2012 | 02:09 PM
Default knock gauge
I have a mephi 4 so it will retard the timing but I just want to be able to see if it is knocking. I had one in my last boat and twice I had bad fuel on the lake and it sure was nice to know!!
I was hoping a supplier might have some in old stock??
Bruce is offline
