Brand New Comp Cams Spring Mic 1.800" -2- 2.200"
60.00 SHIPPED TO YOUR DOOR P.M ME THANKS.
BRAND NEW COMP CAMS SPRING MIC 1.600" -2- 2.200"
Brand COMP Cams
Manufacturer's Part Number 4929
Part Type Valve Spring Height Micrometers
Product Line COMP Cams Valve Spring Height Micrometers
Summit Racing Part Number CCA-4929
Micrometer Range (in) 1.600-2.200
Micrometer Increments (in) 0.005
Maximum Valve Spring Retainer Diameter (in) 1.500
Micrometer Material Aluminum
Micrometer Finish Natural
Measure valve spring height the easy way.
Accurate to .001 in., these COMP Cams valve spring height micrometers are the quickest, easiest, and most accurate way to measure valve spring installed height. They install just like a valve spring, and then the tool is expanded until it has fully seated the valve, locks, and retainer. By simulating the installation, they're able to read the measurement precisely.
Brand COMP Cams
