Build my 598 procharged motor >
Old 12-11-2012 | 09:12 PM
Default Build my 598 procharged motor
Okay, so I am getting ready to start collecting parts for my engine build. I want a large cubic inch procharger motor making 11-1200hp. Help me decide on what parts will get me there. I was thinking........
Dart big m 598
Dart pro 1 345 CNC heads
M-5 pro charger
Callies dragon slayer crank
Oliver rods
Je pistons
Basically getting ready to start building the short block. The main questions I have are what bore and stroke and why? A lot of big hp motors are built from 557 and 565's. Why not go to the 598 or 632? Also what base compression ratio would be ideal, making between 12-15 pounds of boost through a procharger? This is going to be expensive and I want to do it RIGHT the first time. Okay suggestions please.
rob vanharten is offline
Old 12-12-2012 | 12:16 AM
articfriends's Avatar
Dart big m 598
M-5 pro charger
Oliver rods
Je pistons
This is just my personal opinion so I'm sure someone will flame away BUT personally I would rather have a motor with a 4.500 bore and real stabil cylinder walls IF I was building a endurance blower motor and same with the stroke, once you get too much too much stroke, you get tremendous piston speed at high rpm's/cylinder side loading and those paper thin cyl walls start deforming too. I was in Lapouttre racings shop years ago and he had 3 604/632's there with a little smidgen of cylinder web dividing the bores and all of them had blown head gaskets, looked like a bad plan to me, no one will convince me other wise, I would build a 557, 4 3/8 stroke and 4.500 bore and just give it a 1lb more boost, Smitty
articfriends is offline
Old 12-12-2012 | 12:18 AM
Dart big m 598
M-5 pro charger
Oliver rods
Je pistons
m5??? wow i hope you have enough hull to support 1500 hp..start looking for a # 6 drive if you dont already have one lol.try to keep the compression between 8 to 8.5..prochargers like a little more compression..
FIXX is offline
Old 12-12-2012 | 12:34 AM
Smitty, with the piston designs, fasteners, and gaskets that are available today you can make a 4.5" stroke and a 4.600 bore seal ok and not beat up the piston or the bore too bad but, you're 100% right the 4.5 bore 4.375 stroke build is easier on parts, better for an endurance app, and will take a hell of a beating. I like the 4.560 bore 4.250 555" deal as well. The Dart blocks are plenty thick. The big cubes aren't needed at the power level the op is looking for. Hell, 1200hp's no problem with a 540 and an m4. Aren't you making 1100+ with and M3 and a less then stellar intake design?
HaxbySpeed is offline
Old 12-12-2012 | 12:38 AM
Dart big m 598
M-5 pro charger
Oliver rods
Je pistons
Looks like a good build list, the Callies Ultra rods are good too, and Diamond makes some really nice pistons. I'd go with an M4 and EFI, 14lbs boost should be good for 1350ish.
Old 12-12-2012 | 12:59 AM
steveambeo is offline
Old 12-12-2012 | 11:40 AM
Okay so build it off of the 9.8 4.5 bore block. At this level should I be purchasing the block with billet mains, or just the reguler one's?
Old 12-12-2012 | 11:53 AM
Have you took a look at these heads yet?
http://www.profilerperformance.com/r...c-ported-heads
They are outperforming most Dart heads, a much newer intake port design, as well as a thicker deck.
I would just get regular mains if it was mine, and I would not go with to extreme of a stroke, as Smitty already said.
Baldie is offline
Old 12-12-2012 | 03:59 PM
I was just reading through some of Dart's info, and they said the regular mains are good to 1500hp. So that should work. I like the sounds of the 555, that sounds like a nice package. I have never assembled a dart block before. Do the lifter bores need a bushing, or are they good to go.
Old 12-12-2012 | 04:23 PM
TeamSaris's Avatar
Driver-441
Racer
Start with a Whipple lolol
TeamSaris is offline
