What Would 50 # of TQ and HP Gain Get Me? >
Old 12-13-2012 | 11:32 AM
Default What Would 50 # of TQ and HP Gain Get Me?
What Would 50 # of TQ and HP gain get me in a single V hull with 900+HP?
RPMs Gain?
Speed Gain?
Prop Gain?
goebel1 is offline
Old 12-13-2012 | 01:42 PM
This is the info you need to get the answer to your MPH question.
http://www.go-fast.com/boat_speed_predictions.htm
BenPerfected is offline
Old 12-13-2012 | 01:56 PM
This helps... looking for what rpms gains there will be for re-proping. If this is worth doing or not.
goebel1 is offline
Old 12-13-2012 | 02:12 PM
I doubt you will need new props for +50 hp. Play with the formula to get the current MPH. Add 50 HP at the same hull efficency & weight = increase. My guess is 1-2 MPH.
Old 12-13-2012 | 03:05 PM
50hp usually ads around 300rpms, but being that you are already at 900hp, who knows.
Griff is offline
Old 12-13-2012 | 04:17 PM
300 rpm is quite a bit if it will pull that much.
goebel1 is offline
Old 12-13-2012 | 04:27 PM
Using estimates of 90 MPH(seems like you said your were running around 90) as your current speed and 6000 boat weight, my program says you'll gain approximately 2.5 mph with 50 hp. That equates to around 150 RPM increase with all else remaining equal.
Bob Lloyd
Full Throttle Marine
bobl is offline
Old 12-13-2012 | 04:38 PM
Bob Lloyd
Boat is 4800# dry + 40 gal 244#, + heavy ass drive extra 100# and extra gear and bodies 500# =5644# about right.
goebel1 is offline
Old 12-13-2012 | 07:20 PM
articfriends's Avatar
2mph
articfriends is offline
Old 12-13-2012 | 08:41 PM
Default fixx
50 hp may get you broken rods and pistons
FIXX is offline
