Go Back  Offshoreonly.com > General Discussion > Offshoreonly Industry News
Industrial Catalog Volume 2 >
Old 12-13-2012 | 04:55 PM
KennyOffShore's Avatar
Administrators
Default Industrial Catalog Volume 2
December 2012 - Livorsi Marine has a new industrial catalog ready to hit the mailbox. This catalog features the latest innovative products to hit the market: Adjustable Position LED Indicators, hydraulic trim tabs, an electronic foot pedal, fuel level senders, CAN Bus gauges and stainless steel exhaust. Below is a preview of what you can find in the new catalog.
LED Indicators
This indicator eliminates the need for mechanical 33C cables which are typically used for drive or tab indication. These cables are replaced by more reliable network wiring that allows plug and play connectivity into existing tab or drive position sensors.
Hydraulic Trim Tabs
Livorsi’s heavy duty hydraulic trim tabs meet the demands of boats operating at high speeds or in rough water conditions. These tabs incorporate a hinge constructed of extruded aluminum with a 1/2" stainless steel pin to provide unmatched strength and reliability even in large jet pump applications
Electronic Foot Pedal
This new electronic foot pedal is currently designed to control the throttle on PCM and Marine Power engines. A completely electronic design eliminates problematic cables from bow to stern. A fully sealed sensor is used to send the position information from the pedal to the ECU on the engine. These pedals may also be calibrated for MEFI 5 and 6 engines.
CAN Bus Gauges
Livorsi Vantage View CAN Bus gauges are designed to work with any SmartCraft®, NMEA 2000®, SAE J1939 or GM MEFI engines. Vantage View® displays real-time data and compiles the information into one gauge, the Master Tachometer. This tachometer features an analog RPM readout with a built in LCD screen that displays all the information your engine’s ECU provides. This line of instruments is an exceptional tool for monitoring the performance of a vehicle, workboat or powerboat.
Stainless Exhaust
Custom Marine stainless exhaust systems have been installed on more National and World Championship power boats than all other brands combined. CMI is now ready to serve the industrial market with industry-leading technologies, top marine engineers and skilled stainless steel fabricators. Custom Marine, Inc has in house design and CAD capabilities to build an exhaust system for your specific application.
In addition to the new catalog, Livorsi Marine, Inc. is proud to celebrate its 25th year supplying gauges, controls and accessories to high performance, work, commercial and government boats. We look forward to many more years providing the marine and automotive market with forward thinking solutions.
To request an industrial catalog please call 847.752.2700 or email [email protected] with your mailing address.
KennyOffShore is offline
HTML code is On
