Need some advice on gimbal ring install...... >
Old 07-16-2002 | 08:07 PM
Waterfoul's Avatar
Gone Fishin'
Default Need some advice on gimbal ring install......
I have the opportunity to get a transom assembly pretty cheap. Going to look at it tomorrow. So, would you take the gimbal ring out and replace the broken one (drilling the holes in the housing, etc...), or would you lift the motor off the mounts high enough to undo the nuts and replace the entire transom assembly?? Mind you, I would be replacing only the outer assembly. The unit in question even has a new gimbal bearing in it, mine has 7 seasons on it.
Personally, I am leaning towards llifting the motor and changing the whole assembly.
What do you guys think????
Mike
Waterfoul is offline
Old 07-16-2002 | 08:19 PM
traviss's Avatar
I think between your broken parts and mine, we could create a nice piece of art and sell it for a bundle of dough
traviss is offline
Old 07-16-2002 | 08:22 PM
Airpacker's Avatar
pull the mill.if somethings worth doin,its worth doing right.well,thats what my momma always told me
Airpacker is offline
Old 07-16-2002 | 08:23 PM
Smitty's Avatar
Mike,
Change the whole thing out. You don't need to be drillin' holes etc.
Dave
Smitty is offline
Old 07-16-2002 | 08:44 PM
i agree mike if it is better then the one you have, change out, less work in the long run. when you plan on doing this? this weekend, i finally have sat-sun off if you need help let me know.
Scooter is offline
Old 07-16-2002 | 08:55 PM
obnoxus's Avatar
Charter Member #1171
Pull the motor,, if you prep right and get the help youve been offered already,, its a day project,,, you'll be able to trust your repair and wont have to look at the plastic plugs in your transom forever !!!
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 07-16-2002 | 09:13 PM
MitchStellin's Avatar
Pull the motor and put in a TURBINE. No need for that old fashion Bravo Drive. T55 w/3200hp should get you well over 120mph
MitchStellin is offline
Old 07-16-2002 | 09:57 PM
formula31's Avatar
Pull the motor, theres a couple gaskets you will need and be real careful torquing the stupid plastic water elbow.
formula31 is offline
Old 07-16-2002 | 10:02 PM
Waterfoul's Avatar
Gone Fishin'
Hardest part is going to be finding a hi-lo I can use for several hours without interuption. I don't want to take the motor completely out of the boat (that's a real pain in the ass), just high enough to get at the transom assembly.
Mitch, I've already had to re-tap one of those bolt holes for the elbow. bolt broke off the last time I had to take the assembly off. Used anti-sieze on em. Should be no problem.
Scooter, I'll let you know if I need a hand this weekend. Gotta make some calls tomorrow and see if I can get a hi-lo for a while.
How many gaskets and seals do I need?? One on the transom I'm sure, but what else??
Old 07-16-2002 | 10:06 PM
let me know open fri night and sat all day, have to golf with inlaw sun at 12:00 am other then that I'm there for ya
Scooter is offline
