509 600hp  9.5cr dry exhaust 32 fountian >
Old 12-15-2012 | 09:47 AM
glen george's Avatar
Default 509 600hp 9.5cr dry exhaust 32 fountian
Thinking about buying these motors in the swap. On my 32 fountain I need some type of mufflers. I will be removing the silent choice +emi exhaust . With 741 cam and 9.5 cr what options do i have with a dry exhaust to prevent revision? Using the stainless marine manifoilds on the engines and geting bravo pipes. How about using the gibson downturns after drilling a 1" hole above the water line ? or external?
Attached Thumbnails 509 600hp  9.5cr dry exhaust 32 fountian-engine3%5B1%5D.jpg
glen george is offline
Old 12-15-2012 | 10:33 AM
As long as you use the Hp500 tail pipe with the turbolators you should be fine with the Gil's.
KWright is offline
Old 12-15-2012 | 10:43 AM
I have 2 sets of EMI, motors have stainless marine, hope to use either set that i can get a set of risers for later. Do TRS exhaust have more problems with. Revision with performnce cam?
Old 12-15-2012 | 01:59 PM
The Hp500 tail pipes are taller and longer witch helps with the reversion don't see why if you copied a set for the stainless marine why that would work.
KWright is offline
Old 12-15-2012 | 02:11 PM
ROB FREEMAN's Avatar
ok
ROB FREEMAN is offline
Old 12-15-2012 | 02:25 PM
Thumbs up
I ordered 2 xr drives last night. By spring hope to have motors to match.
