Planning on getting Stainless Marine exhaust >
Old 12-15-2012 | 08:03 PM
Default Planning on getting Stainless Marine exhaust
Hi everyone,
planning on going with Stainless Marine exhaust and long risers, and i have a question,based on the pic, do i need to change the thermostat housing to do this switch? since there are 2 hoses coming out of the Tstat going to the risers now and SM's are set up differently with a little hose connecting the manifold to ss riser.Hope someone can answer this since i will go see Jerry ( SM) on monday.
thanks .
Attached Thumbnails Planning on getting Stainless Marine exhaust-454-sr1.jpg
Diego9040 is offline
Old 12-15-2012 | 09:21 PM
Ted G's Avatar
I had the same type housing on mine. The SM manifolds have 2 inlets and that connector hose fitting to the elbow. I put a fitting in each inlet and ran 2 hoses to each manifold, works great.
Attached Thumbnails Planning on getting Stainless Marine exhaust-img_0682-small-.jpg
www.cbpba.com
Ted G is offline
Old 12-15-2012 | 10:22 PM
Ok , so I don't have to change the T-housing? That would be good.
Old 12-15-2012 | 10:34 PM
Ted G's Avatar
Right, you need two 90 degree fittings on the manifolds for the hoses.
www.cbpba.com
Ted G is offline
Old 12-16-2012 | 08:54 AM
Ted,
Thank you,I will bring it up to Jerry at SM.
Old 12-17-2012 | 07:09 PM
I went by SM today,and Jerry hook me up, got the BB manifolds, I will have them installed after new year's .Then,will have them measure the height and
Would I be able to gain any mph just by doing this upgrade? Should I adjust the carbs after install? Any other adjustment?
I am going to check top speed before and after installation, any predictions?again i have pretty much stock bottom end 330's , 781 heads and weiand stealth intake with hp500 carbs.
272 sr1
Old 12-17-2012 | 07:25 PM
diego you may need to rejet, not positive i would at the least check what jets are in there. I have one set of risers cheap if you need them
Unlimited jd is offline
Old 12-17-2012 | 07:38 PM
Hey James,
I know ,I saw your risers ,great price,but the thing is that I had paid for the 2 sets of small blocks and long risers ,now I am just switching to BB manifolds risers will be the same that I had already paid. I am staying with the BB's eventhough the sbc's I built came out nice 400hp @ 5200 rpm and 459lbs/ft of torque at 3000 rpm.
Hope you are doing good.
