Auto Meter White Phantom Pro-Comp Marine Gauges “NEW” (Retail $242.28) >
Auto Meter White Phantom Pro-Comp Marine Gauges ?NEW? (Retail $242.28)
Old 12-17-2012 | 10:20 AM
WildThing's Avatar
Default Auto Meter White Phantom Pro-Comp Marine Gauges “NEW” (Retail $242.28)
Auto Meter White Phantom Pro-Comp Marine Gauges “NEW” $140.00 + Shipping (Retail $242.28)
The Auto Meter Pro-Comp Marine Gauges are built in the world renowned tradition that's made Pro-Comp the standard of racing gauges throughout the world and Auto Meter puts rugged, race-proven movements into everyone of their gauges. When we talk about "Marine Gauges" no one knows how to build more durable instruments than the guys that build nearly every racing gauge in the market today. The "AUTO METER MARINE DIFFERENCE" comes in the construction of a marine gauge. These gauges feature aluminum cases (automotive versions are steel). These marine gauges also use non-corrosive internal and external components to withstand harsh marine conditions, marine mounting hardware with weather resistant sealed lenses to help prevent moisture and fogging inside the gauges. Superior quality internal components and UV fade resistant race pointers insure accurate and rapid gauge response readings
All Lenses Sealed
All Faces: White
All Needles: Red
All Lettering: Black
All Bezels: White
Auto Meter White Phantom Pro-Comp Marine Fuel Gauge
AM Part Number: 200761 (Retail $39.83)
Range: for 240-33 Ohm sender (12V)
Diameter: 2 5/8" (66.7mm)
On Dial: FUEL LEVEL
Notes: Electrical 240E Ohms empty / 33 Ohms full sender.
Auto Meter White Phantom Pro-Comp Marine: Engine Oil Pressure Gauge
AM Part Number: 200759 (Retail $38.69)
Range: 0-100PSI
On Dial: OIL PRESS
Notes: Electrical Requires 240 / 33 Ohm pressure sender (below)*
Auto Meter Pressure Sender: 100 PSI
AM Part Number: 2242 (Retail $29.90)
Range: Pressure Sender: 100 PSI
Notes: For 100 PSI electric oil press gauge (above)*
Auto Meter White Phantom Pro-Comp Marine: Engine/Water Temperature Gauge
AM Part Number: 200763 (Retail $39.56)
Range: 100-250F
On Dial: WATER TEMP
Notes: Electrical Requires 433 /17 Ohm sender (Mercury match) (below)*
Auto Meter Temperature Sender
AM Part Number: 2258 (Retail $13.80)
Notes: For Short Sweep electric temperature gauge (above)*
Auto Meter White Phantom Pro-Comp Marine: Water Pressure Gauges
AM Part Number: 200773 (Retail $42.07)
Range: 0-35 PSI
On Dial: WATER PRESS
Notes: Mechanical. 1/8 NPT Connection.
Auto Meter White Phantom Pro-Comp Marine: Voltmeters - 12 Volts
AM Part Number: 200757 (Retail $38.43)
Range: 8-18 Volts
On Dial: VOLTS
Notes: for 12 volt systems.
Sender: No Sender Required
Call Ron 937-286-3865
WildThing is offline
Old 12-17-2012 | 11:05 AM
send me paypal info i will take
watts up is offline
Old 12-17-2012 | 05:28 PM
WildThing's Avatar
Check your inbox...paypal info sent....Thanks
