Broken Upper Gears in a Blackhawk >
Old 07-16-2002 | 10:42 PM
Default Broken Upper Gears in a Blackhawk
Well, I got the verdict from the mechanic. I broke off two teeth on a gear in the upper end of the Blackhawk Drive. The drive wouldn't go into gear because the drive was trying to grab the gear where the teeth were missing. He told me that I basically need new upper half gears. He did say that mercruiser makes gears for both gas and diesel engines for the Bravo. The diesel gears are supposed to handle a higher load. He told me that he normally puts them in any Bravo that has to handle 400 HP or more. He said that normally, the drive gets torn apart when a tooth breaks off, but mine looks fine, probably lucky. The price of the upper gears is around $900. Does that sound about right?
IHTFP is offline
Old 07-17-2002 | 06:42 AM
Mbam's Avatar
Offshoreonly Advertiser
Price sounds about right, but make sure he uses the latest gear upgrade kit from Merc. There are no longer diesel gears, the diesels are now X drives. The new gears are much stronger than what you have now.
Mbam is offline
Hot Boat
Drives and Lower Units
12
12-22-2007 12:27 AM
Illusive
10
07-10-2007 07:51 AM
johnnyboatman
05-02-2006 07:15 AM
otis311
6
06-26-2005 09:55 PM
Rookie
2
04-06-2005 07:00 PM
