Aluminum block in boats ?? >
Old 12-19-2012 | 07:34 AM
Default Aluminum block in boats ??
Why don't you see more all aluminum blocks in the fresh water boats ? Are there any negitives to this in reguards to it being in a marine environment ? My current boat is all aluminum and I hope it serves me well,time will tell. hf...
halffast is offline
Old 12-19-2012 | 08:40 AM
mcollinstn's Avatar
The only negatives are:
cost and much more sensitive to corrosion than cast iron.
mcollinstn is offline
Old 12-19-2012 | 09:01 AM
Cost, and most boaters aren't worried about trying to save 200 lbs in a twin engine boat.
In cars weight savings means increased MPG.
We worry about GPM.......
wannabe is offline
Old 12-19-2012 | 09:13 AM
Registered User
Most common aluminum blocks are probably 5.7's & 5.3 SBC's anyway they are still kinda pricey, the thing I ran into was making it stand alone power there is so much wiring, modules, & water sensitive stuff. The risk didn't seem worth the reward. IMO
For instance I just sold a blown LS1 with wiring harness basically stand alone power. Engine was totally disassembled & needed block, cylinder & head work. I was asking 3K got 2700.00 SOLD!
GTOKILLER is offline
Old 12-19-2012 | 09:14 AM
Registered User
Old 12-19-2012 | 10:30 AM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
One of my cat buddies has an aluminum Donovan 540 in his 26' Daytona . Only problem is getting and keeping heat in the oil and there are remedies for that .
the deep is offline
Old 12-19-2012 | 02:10 PM
c_deezy's Avatar
The 'Razzmatazz' 38 Flat Deck that sold not too long ago had some big Donovan aluminum blocks in it. I think they were like 622 or 632 or something like that.
c_deezy is offline
Old 12-19-2012 | 03:01 PM
even in fresh water any aluminum block or heads are going to corrode...best bet is a closed cooling system and anti freeze in the engine...
ezstriper is offline
Old 12-19-2012 | 04:09 PM
Cost..
Pismo10 is offline
Old 12-19-2012 | 04:42 PM
Good , Feel better now. hf ...
halffast is offline
