86 scarab panther trs to brvo swap >
Old 12-24-2012 | 09:59 AM
hullofjustis's Avatar
Default 86 scarab panther trs to brvo swap
I am redoing an 86 scarab panther that when i bought was a running bot and it ran well, but because i can't leave anythin alone and engine room floor/hull starting to delaminate in small area or should say thought was a small area, i removed the engines and trs assembly's and ended up replacing transon and stringers to the gas tank bulkhead. So with doing that i am convrting to bravo's with 3 up imco extension boxes and with the drives propshafts being 3 3/4" below the bottom and with -2 imco drives will be at 1 3/4" below the hull. This has made interesting for exhaust fitment. So after transom and stringers were done the bottom was redone. I am now getting ready to assemble the blocks with cms racing engines. Twin 502 ci 600hp a piece. My question is, has anyone played with prop rotation. I know trs can only spin one direction in forwad but anyone who has a bravo panther and have messed with props spinning in or out could you let me know your results please. Great work with all your panthers they look great!!!
hullofjustis
hullofjustis is offline
