# dyno #s sbc
Old 12-31-2012 | 08:13 PM
Default # dyno #s sbc
Any guessers out there.
Dart shp block 385 cid
Eagle 3.75 forged crank,& 6" rods w/their esp treatment
-16 Srp slugs fitted w/Mahle rings.
Clevite
Madara (rm builder ) stick
lsa 112, 6.9 overlap, 1.5 ratio, duration I=228 E=234 lift
.5553 .53415
Morel retro
Manley pushrods
AFR 195 aluminum milled to 70cc
Scorpion 1.5 rockers
Rpm air gap
Pro Systems carb
Msd ignition
all Arp fasteners
Andrew 19 is offline
Old 12-31-2012 | 08:19 PM
I would be surprised if it didn't make 450 HP and 475# TQ....with the right tune.
sprink58 is offline
Old 12-31-2012 | 09:01 PM
Clevite
.5553 .53415
Morel retro
Manley pushrods
Rpm air gap
Pro Systems carb
Msd ignition
all Arp fasteners
The cam is to small for big power i have 335ci with 12.1 with 58cc alum heads 740 lift rollor cam made 685hp
kidapache is offline
Old 01-01-2013 | 01:12 AM
418 hp @ 5800 rpm
Trash is offline
Old 01-01-2013 | 03:18 PM
I would say 480 lb/ft @ 4500 RPM and 470hp@ 5500RPM. These are through the dyno headers. I would expect one of Bob's cams to hold the hp within 2 for about 4-500 RPM. My 383 was very similar with Bobs cam in it and a set of ported trick flows, I was running a single plane though.
ACrooks69 is offline
Old 01-01-2013 | 07:12 PM
Default fixx
ya @ 7500 rpm's..
FIXX is offline
Old 01-03-2013 | 07:53 PM
sbc #s
462h 459t
Incorrect metering blocks out of the box. Patrick to ship new ones ASAP. don't know if I'll pull again.
This engine replaces a 1988 350 mag 250-270h 300-325t.
Going in a 5000# bow rider.
Mr Gadgets building me a BADD AZZ B 1 . Thanks for the intrest.
Lots more of this story to follow.
P.T.L.
Rory
Old 01-03-2013 | 11:05 PM
what RPM did they happen to occur at?
Old 01-05-2013 | 07:27 PM
hp @5700 tq@4700
@3600 h=295 t=430
What are good a/f #s ??. Thanks for the input.
P.T.L.
Rory
Old 01-07-2013 | 01:04 AM
Kind of depends. No load idle you can run 13.8-14.0 when warmed up.
For a N/A motor 12.8-13.2 is usually a safe starting point.
Trash is offline
