572 talldeck fit ment in older icbm
well just got my new pfaff motors . they now are talldeck blocks with cmi headers anyone have an idea if i might have a clearence prob . pfaff was told what they were going in , any insight . side by side application .
great . how much wider is a tall deck , 1/4 inch i just got done looking at my old motors in boat and have at least 1.5 to 2 inces between manifolds ?
standard deck on the ole engines are 9.800..tall deck is 10.200 all the way up to 11.100+ depending on the mfr..so it could vary depending on what your deck height is..
Check your center to center measurement. Fitment will depend on a few things. The specific cylinder head you are running will have a big effect. Most aftermarket heads have raised exhaust ports. Most are in the .400-.600 area. The exhaust itself will also effect it. I can tell you this much. A pair of tall decks, with .600 raised port heads and E tops needs at least 34" center to center to fit side by side.
Eddie
Eddie
Rob,
AlsolLook at this thread, I think 88 bullet put tall decks in, tight fit.
http://www.offshoreonly.com/forums/f...e-restore.html
