all sorts of various parts >
Old 01-02-2013 | 03:34 PM
TomFTM's Avatar
Default all sorts of various parts
here is a few pictures of stuff I'm listing for sale.
trs gimbels and transome plates $250each
trim pumps older style $60 each . they all work
trim pump plastic res. $75
merc mcm bbc drive plates $50 both
merc mcm trs input shafts $75 both
trs velvet drive plate $50
2 big block stainless water entry connections $40
compass ss5000 $300. mint
actuator indicators for 3 drives , $75each
brass flame arrestors 8x3 $40 each
steering wheel with trim $25
small block wiring harness $25
4 braided water hoses $25
2 trs external line trim pistons need new wipers . $100 both
2 top mount trs wolverine marine steering brackets $75both
3 grove small block circ pump pulley $15
speedo's $20 for dry, $25 for each liquid filled .
small block oil pan$20
fountain dash $40
bbc chevy rear mount starter $40
volvo service manual $25
small power steering brackets $20 each
gen 5 big block water /fuel pump housing. $40
two into one flush set up brass ball valves $40
trs saddles and tie bar. tie bar needs new joints $60
post here , PM me or call 516-609-0499 Tom
Attached Thumbnails all sorts of various parts-sam_0259.jpg   all sorts of various parts-sam_0260.jpg   all sorts of various parts-sam_0261.jpg
TomFTM is offline
Old 01-02-2013 | 04:06 PM
Interested in the steering wheel. Could you post/send a picture? Will it need a hub to fit a stock 88 Scarab steering set up?
Jeff
[email protected]
sbslinde is offline
Old 01-02-2013 | 04:09 PM
TomFTM's Avatar
Jeff
[email protected]
its in the picture I posted and it has the hub for the 3/4 inch taped shaft. Tom
TomFTM is offline
Old 01-03-2013 | 10:39 AM
TomFTM's Avatar
water hoses sold.
TomFTM is offline
Old 01-03-2013 | 03:33 PM
Sick Stinger's Avatar
Brotherhood #1
Tom 75 shipped on the plastic res trim pump? If so I'm in
Sick Stinger is offline
Old 01-04-2013 | 08:31 AM
TomFTM's Avatar
Mike thats fine , pm ur info . Tom
TomFTM is offline
Old 01-04-2013 | 09:09 AM
Brotherhood #1
Thanks Tom and happy new year to you sorry we have spoke more, pay pal or check?
Old 01-04-2013 | 10:02 AM
TomFTM's Avatar
check is fine
TomFTM is offline
Old 01-04-2013 | 10:18 AM
johnnyboatman's Avatar
Pics of the water dist , do you have 9pin wiring harness engine side i need 2
johnnyboatman is offline
Old 01-04-2013 | 11:32 AM
Brotherhood #1
Tom just get me name and add. Ill get your check out tomorrow morning
