Best cam selection? >
Best cam selection?
Best cam selection?
Old 01-04-2013 | 08:23 AM
Registered User
Default Best cam selection?
SBC 377 8:1 comp. full roller, cast heads 202/16 valves. With Weiand 177 whats your opinion??
GTOKILLER is offline
Old 01-05-2013 | 01:42 PM
mcollinstn's Avatar
You've only given about 8% of the required information needed to make a cam recommendation.
mcollinstn is offline
Old 01-05-2013 | 03:57 PM
Registered User
Well I'm open to questions, thats why I asked. what else do you need?
Old 01-06-2013 | 06:08 PM
call BOB MADERA and have him spec a cam for you.
innerrage is offline
Old 01-06-2013 | 10:15 PM
I have had Comp Cam make cam's for me . They were plenty helpful , tell them what you have and what you are after and they will fix you up .
Jeff P31 is offline
Old 01-06-2013 | 10:57 PM
Originally Posted by innerrage
call bob madera and have him spec a cam for you.
+1
mustangmark is offline
Old 01-07-2013 | 12:56 AM
Crower has a set of hyd roller EFI/Blower/NOS cams that work well.
Trash is offline
Old 01-07-2013 | 02:42 AM
boyomarga is offline
Old 01-09-2013 | 05:36 PM
mcollinstn's Avatar
What heads/what cc?
What squish height are you running?
What carb?
What boost do you plan to run?
What would you like your max rpm to be?
What is your expected cruise rpm?
What boat/type/weight?
What type of boating do you do?
Do you plan to pull wakeboards/skiers/tubes? How often?
What octane fuel do you plan to run?
That's a START.
MC
Old 01-09-2013 | 08:55 PM
Registered User
Thanks for the suggestions I had Comp grind me a couple for my exact use.
