Standard to monster size gauges without new dash? >
Old 01-04-2013 | 09:10 AM
Default Standard to monster size gauges without new dash?
Just curious if there is enough room to enlarge the holes on the dash and replace the old size with monster gauges and no bezels?
Have a friend that did this on his 388 hustler. Curious if anyone has done it on a fountain?
4bus is offline
Old 01-04-2013 | 11:07 AM
Eddie Young recently just finished putting monster guages in mine . they look great !!!
575cat is offline
Old 01-04-2013 | 02:59 PM
I was able to do all the gauges except the Tachs.
Attached Thumbnails Standard to monster size gauges without new dash?-photo.jpg
Back4More is offline
Old 01-04-2013 | 03:49 PM
Thank you, looks great btw.
Did you use the old dash panel or cut a new one? I noticed the indicators are different
4bus is offline
Old 01-04-2013 | 04:11 PM
Its just a flat piece of Aluminum, couldn't you just get a piece, and lay out a new one using the old as a template for everything?
Wildman_grafix is offline
Old 01-04-2013 | 06:33 PM
Thats a new one from Livorsi. The old one had a lot of wasted space not being utilized.
I went with the stainless steel thinking it would be stronger since we cut a ton of holes in it.
Old 01-04-2013 | 07:20 PM
I guess you could, just a lot of cutting. Indicators would be a pain
4bus is offline
Old 01-04-2013 | 07:22 PM
Thats a new from Livorsi. The old one had a lot of wasted space not being utilized.
Wanted to avoid that and just open up the old one if possible.
Why did you switch to the enclosed indicators? Did they have trouble cutting for the fountain style?
4bus is offline
Old 01-04-2013 | 07:29 PM
I wanted the back lit indicators so you can see them at night.
Also the old style rattled.
Old 01-05-2013 | 08:36 AM
Did he replace the dash panel?
4bus is offline
