74 Magnum Maltese
After quite a few years of walking by this boat everyday the ugliness has begun. Other than the exhaust and drive cut outs there was 179 holes in the transom. Had to drill 1 more just to make it an even number. More pics to be added as they get taken
http://tomsprojectboats.shutterfly.com/pictures
Love the old Magnums...what's your plan? Total update or an original restoration?
I would love to see one of those as a sleeper with a pair of blown LS motors. Imagine 1100~1200 horsepower shoving that bullet around!
Sprink, going to do a kind of retro-rod. I have 95% of the hulls original equipment. A pair of small blocks I have had laying around the shop. Freshened up of course. Trying to work out a pair of volvo duo-props for drives. Unfortunately the girl friend likes the Big Cris Craft, so funding for my demise is severly limited.
Micky, I sanded everything with a dewalt orbital and 320 grit. I was amazed the condition of the original gelcoat. Still have to do the little corners and the bottom yet.
The boat will be a Bullet.
Seebold, I sat down for a couple of hours one day and stared at the transom trying to figure the mess out. This is what i managed to come up with. K plane mounts with hoses that went up to merc thru hull fittings, dual ram hydraulic steering mounts plus 2 hoses on each side, custom hydraulic trim cylinders on each side of the drives, hoses go up to merc thru hull fittings, indicator cables for tabs and possibly both drives, 1 stern eye on each side, strap for lifting ring in the center, crap load of stupid holes I think to try and dry/drain the transom. Oh, 2 water pick ups. I am planning on a much cleaner transom.
