78mph 26Baja out of the gate >
Old 07-17-2002 | 11:03 PM
Audiofn's Avatar
Charter Member #232
Default 78mph 26Baja out of the gate
Still lots of testing needs to be done but that speed is not bad for the first day
Put your best foot forward!
Audiofn is offline
Old 07-17-2002 | 11:24 PM
Mark in So. MD's Avatar
Sounds good, hopefully you will get more after testing and damm you got a lot of horses under that hood. Best friend has the same boat, with 550hp(dynoed) and he even did hull work(sanded the end of the hull where baja put a little small hook in each side of the hull) and he only got 76mph.
Mark in So. MD is offline
Old 07-17-2002 | 11:26 PM
Whoops, his is a 25, now considered a 27 because of the swim platform.
Old 07-17-2002 | 11:37 PM
Audiofn's Avatar
Charter Member #232
Mark you could be right a 25. I keep calling it a 26 footer but I think it is the 25.
Jon
Audiofn is offline
Old 07-17-2002 | 11:46 PM
25 Eagle
Question
What kind of power?
Old 07-17-2002 | 11:49 PM
Audiofn's Avatar
Charter Member #232
Never dynoes but it is a 454 Mag to start its life and had some head work, roller cam, and procharger put on. It is running 5 pounds in the intake for boost. The estimate was around 650 or so.
Jon
Audiofn is offline
Old 07-17-2002 | 11:53 PM
25 Eagle
What kind of speeds do you think your hull is good for? You should be getting close.
Old 07-18-2002 | 12:02 AM
Audiofn's Avatar
Charter Member #232
Not my boat it is a friends. I would think he is going to be going a solid 80 by the time he gets it all tuned in.
Jon
Audiofn is offline
Old 07-18-2002 | 12:16 AM
stevejohns
Very cool !!!!!!!!!! My 92 21 foot baja has the same paint job. i have a 530ish 502 that i just installed gil exhaust on. So far my gps max was 74 . I have some new props to try and would love to report 80. But i think im over expecting. Beautiful boat dude !
Old 07-18-2002 | 12:22 AM
25 Eagle
That should be a interesting ride. Is he running a dual ram setup,swinging a 28P? Just wondering as I am running 72mph/gps 502/415 and from what I'm told a Whipple would put me in the scary zone.
