Dumb question >
Dumb question
Dumb question
Old 01-10-2013 | 07:15 PM
Question Dumb question
The green wire on this parallel switch by passes it right.
The switch is just a heavy duty solenoid??
ICDEDPPL is offline
Old 01-10-2013 | 07:26 PM
Yep, big switch that is now jumped
Unlimited jd is offline
Old 01-10-2013 | 07:59 PM
No wonder half my **** is still on after I turn off the switches.
Couldn`t I just put on a manual on/off switch? the Dash toggle is just convenience right
Thanx lil!!
ICDEDPPL is offline
Old 01-10-2013 | 08:13 PM
Yes you can replace that solenoid with an on off switch, the dash switch makes it possible to open the hatch when the batteries are all half dead, so if you do install the on off switch mke sure it's not under the hatch!
Old 01-10-2013 | 08:14 PM
I think you only have on/off battery switches. Jumping the battery parallel solenoid gives you better cranking. Cig didn't uses the biggest battery cable back in the day.
kvogt is offline
Old 01-10-2013 | 11:48 PM
Full Force's Avatar
I would leave it factory setup as it was designed to jump one engine if one battery dies... it saved me last summer when I lost charging in one engine, battery was not charged enough to start it, fired good engine, hit switch and fired the other, still didnt charge but it got it going enough to get me back on 2 engines, I now have a charging jumper wire with a fuse to link the two together for charging if I lose charging ability again on one of the engines...
Full Force is offline
Old 01-11-2013 | 08:26 AM
No biggie, since its in the bilge I ordered a new one. I don`t like em in parallel full time.
ICDEDPPL is offline
Old 01-11-2013 | 11:43 AM
When replacing these jumper solenoids, I believe you would want constant duty solenoids as opposed to starter solenoids since they would typically be switched on for extended periods of time. Bill
Conquistador is offline
Old 01-11-2013 | 11:46 AM
Full Force's Avatar
In my mistress you would have to hold the parallel switch manually to have it on all the time... I would think they are all like that since the reason is to jump the other engine
