Prop Dyno Questions... >
Old 01-11-2013 | 08:25 AM
Default Prop Dyno Questions...
Any members have experience with prop dynos? I have been told that it will simulate the load of the boat being on water and it will handle the RPM of my motors all the way to WOT. Reason I am asking is I just had a bunch of motor work done on my boat which is completed and ready for pick up, but due to the location and time of year I will most likely not be able to get it in the water for a sea trail. They do have a prop dyno though and advised that I can run it on that. The company who has done the work has been nothing but great to me and its not that I dont believe them with what they say about the dyno's performance, I just do not know enough about them to feel comfortable about just using it and not sea trailing the boat after the work that was done before I hook up and bring it home. Any thoughts/opinions or anybody that has experience with prop dyno's would be appreciated.
Prowler26 is offline
Old 01-11-2013 | 09:40 AM
Randy Nielsen's Avatar
I had a small one at my shop that was more for smaller engines, pretty simple waterbrake fed by a garden hose. Worked ok but not suited to supply enough water to the engine for cooling under load. Mine would measure up to 300hp it said but I would never push an engine to that level because of the cooling set up. Like I said mine was small & rolled around on casters. Randy
Randy Nielsen is offline
Old 01-11-2013 | 10:15 AM
Most shops just have a dyno that is capable of loading the engine, but don't give any real data. It still will give you a good idea if the engine is running correctly. Land & Sea makes a real nice unit that can measure 800 HP at the prop and software that will give you good data just like on a regular engine dyno. That's what I have and have dyno'd hundreds of boats at the prop.
Bob Lloyd
Full Throttle Marine
bobl is offline
Old 01-11-2013 | 10:33 AM
Talk to Bob he published a bunch of tests on different exhaust systems a while ago to give true power readings. He should be able to tell you whether that is a good idea or not. Randy
Old 01-11-2013 | 11:09 AM
Thanks for the reply's. I believe the prop dyno the company has, is rated up to 850hp or somewhere in that ball park. I'm sure they would not buy junk products either so I am pretty confident that the prop dyno they use/own is top of the line. I was just unsure if it really puts a good idea of a load on the motor with out being in the water. I know putting it in the water is the best option but mother nature really controls if that is going to happen or not.
Old 01-11-2013 | 11:58 AM
"Yes" would be the answer to your question. About the only thing they couldn't check would be water leaks that would only show up in the water.
Bob
bobl is offline
