Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
OK to notch stringers for clearance? >
Old 01-11-2013 | 09:39 AM
Default OK to notch stringers for clearance?
I have an 88 Baja 235 Force, and while the engine is out, I was thinking about extending the notch in the rear stringers a few inches further forward to give me a little bit more room to get to the starter if necessary and the oil filter (using a t-stat sandwich oil cooler adapter). There are already two notches back there that extend all the way to the stringer forward about 8 inches or so - the notches are about two inches deep off the tops. I can't see how extending them forward a little bit could upset the structural integrity of the motor mounts, but I thought I would run that across some of the fiberglass experts. Of course, I will go back and encapsulate the cut area with fiberglass cloth and resin and bilge paint.
I'll post a picture if necessary. I'll be in there working on it this weekend. Thanks.
Budman II is offline
Old 01-11-2013 | 10:26 AM
1988 boat I would be concerned with Moisture in them.
Leave them stock, Buy Mini HP starter
Tcraft is offline
Old 01-11-2013 | 11:02 AM
Yeah, that thought went through my mind - I might not want to know what's on the inside of them. Should be able to tell if there is any moisture in that area by simply drilling a small hole (of course, remembering to fill back in if I don't notch them). More concerned if it would weaken anything structurally. I'll have to post a picture over the weekend.
My real concern is less on the starter side (already have the mini Merc starter) and more on the port side for oil filter clearance. I added a thermostatic sandwich oil filter / cooler adapter, and the filter mounds directly to it. Makes changing filter a bit of a pain, but eliminates about 5 feet of restrictive oil cooler lines and fittings. The goal is better oil flow to the engine, and the ability to keep the oil up to proper temp.
Old 01-11-2013 | 12:12 PM
Get her solid/Investigate possible Trouble.
That way no Issues pop up in the Season.
Engine out is Best Time, tighten the Bolts with confidence
Tcraft is offline
Old 01-13-2013 | 02:08 PM
Default Picture's worth a thousand words...
Here is a picture of what I am trying to accomplish:
Yellow line is approximately where I want to notch for additional clearance. Any issues with doing this?
Old 01-13-2013 | 08:01 PM
johnnyboatman's Avatar
While its out if your not using the exhaust y yank it out to. I dont think it would hurt anything to notch the stringer.
johnnyboatman is offline
Old 01-13-2013 | 08:16 PM
I would like to get my switchable exhaust functional again, but I need to get the right kind of collector with a built-in diverter for my Lightning headers.
