McLeod Actuators >
McLeod Actuators
McLeod Actuators
Old 01-13-2013 | 10:15 AM
Default McLeod Actuators
Anybody know where to get the actuator motor for the newer style McLeod (2003) with the electric actuator? I believe it is screw style...
Keith Atlanta is offline
Old 01-13-2013 | 02:15 PM
call sunsations boat in mich,,,they should be able to help
TWIN-SPINS is offline
Old 01-14-2013 | 08:38 AM
Anybody know where to get the motor?
I dont want this to be a weekend project when it can be 20 minutes to install both motors.
Old 01-14-2013 | 08:58 AM
I cannot remember the company name but there was a brand listed on my motor. I called that company and got two motor to screw Jack couplers. I will did thru my notes.
looseconnection is offline
Old 01-14-2013 | 02:25 PM
Call Justin at Mcleod Designs. He can point in the right direction.
248.588.1166
Jason3603 is offline
Old 01-14-2013 | 03:25 PM
I cannot find the mfg in my notes. Good Luck
Old 01-14-2013 | 07:04 PM
Try this:
AccuLift Inc.
17516 Dix
Melvindale, MI 48122
313-382-5121
Part # C-4.5-7.50 for the assembly. The motor is PJ24036Q 12vdc
Mine are 2005 on a formula 382. Assembly is around $450.00
BE CAREFUL !!!! The part number above is for a McLoed 300 series bolster and might be unique to Formula !!!!
I think McLoed has also used Motion. Josh at Donzidirect.com has them from Motion for $495.00. Better verify before you spend the $$$.
Andy
PremierPOWER is offline
Old 03-24-2013 | 07:01 PM
I ended up diagnosing this - thankfully I didnt spend $900 on motors.
Neither motor worked. Both sides had corroded wires & they both stopped working within 1 month of each other. Put the test meter on them and realized the connectors were corroded where they crimped to the wire. Replaced the main positive and negative connectors and two switches total of a whopping $30 for everything. It was nice fixing a problem for less than a $grand....
