"What's New In Piston Rings" >
Old 01-18-2013 | 07:27 PM
Default "What's New In Piston Rings"
While searching the web for various things engine related I came across this article on Piston Rings from HotRod Magazine. It's not really what's new since the article is from 2009 but I thought it was worth sharing anyway.
http://www.hotrod.com/techarticles/e...h/viewall.html
Jason3603 is offline
Old 01-18-2013 | 09:02 PM
Good article Jason. Thanks for sharing.
What rings are you planning to run in your new builds?
MILD THUNDER is offline
Old 01-19-2013 | 12:16 PM
I was going to run a ductile iron top ring with a plasma-moly face and cast 2nd with standard oil ring tension. After reading that article I am having 2nd thoughts due to the boost I may put to her.
I am now leaning toward a steel or ductile ironl top ring facing material. I'm open to suggestions.
Old 01-19-2013 | 01:26 PM
PatriYacht's Avatar
It probably depends on how much boost you plan on running. Plasma moly is ok for 5-7 lbs. For higher boost you might want to look at Hellfire rings. I'd check with their techs about use in an endurance engine though. Some guys say they cause more cylinder wear.
PatriYacht is offline
Old 01-19-2013 | 01:33 PM
+1 on the hellfire rings. I was told same thing about them causing wear on the bores, but mainly on a production block. I think they may be fine on a dart block.
Old 01-19-2013 | 02:03 PM
Can you bring some clarity to what a hellfrie ring is? It appears to be an Iron ring with a ductile iron facing material. I'm guessing each vendor offers a hell fire style ring??
Old 01-19-2013 | 02:28 PM
Originally Posted by Jason3603
Can you bring some clarity to what a hellfrie ring is? It appears to be an Iron ring with a ductile facing material. I'm guessing each vendor offers a hell fire style ring??
Extremely hard tempered super duty ductile iron ring. Can handle lots of nitrous, boost, etc.
heres some good reading about rings on another forum...
http://speedtalk.com/forum/viewtopic.php?f=1&t=3923
Old 01-20-2013 | 02:57 AM
Check out the "napier" rings....I used them in mine last winter when I did my build. I used the Total seal plasma molly top ring, napier 2nd ring and a std. tension oil ring.
mustangmark is offline
Old 01-20-2013 | 11:17 AM
anything over 600 hp,i like the total seal 0 gap top ring set,they show really low leak down numbers.
mike tkach is offline
Old 01-21-2013 | 07:22 AM
I am using the Total Seal Max-Seal gapless rings in my 540 build. I had the hellfire rings before and they didn't seem to seat that well/quickly but it was a N/A setup built for future boost.
Gimme Fuel is offline
