When to upgrade steering? >
Old 01-20-2013 | 08:38 AM
Default When to upgrade steering?
I have an Essex Valor 24' with a 496 HO. I am installing my new whipple. I am estimating I will be in the upper 70s or very low 80s when done. Do I need to upgrade from the bravo steering. I have seen dual and single ram external and also internal hydraulic. Any advice would be appreciated. Obviously I'm looking to stay as economical as possible. The current set up seems to have more play than it should as is so I am considering an upgrade.
Cheetah is offline
Old 01-20-2013 | 08:58 AM
It seems bravos start to wag the tails in the water past 70 also wears the gimbal faster. get twin ram steering if you can swing it. If you look in the sway shop goods deals can be had.
professor_speed is offline
Old 01-20-2013 | 09:10 AM
Expensive Date's Avatar
Yes, big time. Plus it will make much more stable.
Expensive Date is offline
Old 01-20-2013 | 09:19 AM
ROB FREEMAN's Avatar
spendy .but dam what a differance you will see . its worth every penny .
ROB FREEMAN is offline
Old 01-20-2013 | 11:01 AM
i have always heard that 70 mph was when you should consider hyd steering,but i believe it also depends on the hull.
mike tkach is offline
Old 01-20-2013 | 11:59 AM
Or the size of your cojones!
Old 01-20-2013 | 05:52 PM
Old 01-20-2013 | 06:04 PM
Safety!
PremierPOWER is offline
Old 01-20-2013 | 07:20 PM
Is there a preferred brand or any to stay away from.
Ballpark cost? thanks for the help!
Cheetah is offline
Old 01-21-2013 | 05:57 AM
If you ever saw a housing failure you would do it now....
ezstriper is offline
