sitting blue 525.... >
Old 01-21-2013 | 08:27 PM
Question sitting blue 525....
i have a question to see what others think.....i have an early serial # merc. blue 525 all stock with just under 100 hours on it. its been sitting for about 2 years and going to put in my 2006 daytona 27... Question is should i replace the valve springs? i talked to merc racing tech support and they are telling me it will be fine. they said if it had 300 hours on it and sat for 3 or 4 years or had rust on them then yes... mine look brand new still no rust or imperfections. i know valve springs can be the "weak" link.. but in this case not sure. let me know what you guys think. thanks!
daytona27 is offline
Old 01-21-2013 | 09:55 PM
under 100 hrs,they should be ok,but they don,t cost that much and are much easier to change if engine is out of the boat.
mike tkach is offline
Old 01-23-2013 | 10:56 AM
Thumbs up
keep this in mind,if you replace them now you will get almost 100 xtra hours before you need to address the spring issue,for me,there would be new springs installed before i installed the engine,knowing that the springs are the weak link,id say it,s a no brainer.good luck no matter what you decide to do.
Old 01-23-2013 | 11:03 AM
I agree they SHOULD be ok, but, heres my view.
The engine is out and on the ground. Replacing the springs would be very easy at this point. Cost isn't a big deal as long as you don't buy them thru merc.
New springs in there, with only 100 hours on the engines, once installed in the boat, I think you'd be golden for a while. And not have valve springs tapping you on the shoulder whispering in your ear every time you run across the lake at wot.
Ive done lots of things over the years where I felt things were 'ok', and decided to reuse or run with. Im probably overly paranoid, but, not once did I ever replace something that may have been questionable with new, and regret it.
MILD THUNDER is offline
Old 01-23-2013 | 02:17 PM
obnoxus's Avatar
Charter Member #1171
Was the motor spun over occationally while sitting?
If not.... 100% change them
If it was spun over every couple months,,, I MIGHT risk it if they look good,,,, and if its an easy engine to work on while in the boat,,,,if not,,,,still chage them while its on the floor
I would also pre lube the motor before I started it
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 01-23-2013 | 06:03 PM
the engine was not spun over....just cylinders oiled... the valve springs through teague are about $440.00... that isnt much for insurance, but why spend it if you dont have to. my buddy also says to replace. its just one of those things that is a 50/50 chance. they will most likely be ok but if not its going to do alot more damage. ive built 540ci. engines in past that have sat 6-7 months and never had any issues, but this is almost 2 years this march.....i could probably find out but does anyone know what the spring tension should be. i could pull them and have them checked.... its just hard to spend that kind of money when they look so nice and new already in there.... lol... thanks for all your replies....
Old 01-23-2013 | 09:45 PM
Strip Poker 388's Avatar
Rob
I belive the 525's had better springs than the 500efi,I would run it,It not a big deal replacing them later on,yea its easyier now.
also you should beable to find springs under 175.00!!!!
Rob
ohyea.Ive got a buddy with a 2001 fasttech with 500efi's with around 600 hours on the hole motor,and he murderes it, Yea it make puke ,just saying some people are lucky,lol
Strip Poker 388 is offline
Old 01-23-2013 | 11:22 PM
Boater8987's Avatar
Airking
I would think that the manufacturer that designed, engineered, built and have to warranty the motors would carry the most weight in a decision. I realize they are out of warranty but should be fine. If you have plenty of money to spend then go ahead and change them. I'm not an expert, just an opinion.
Boater8987 is offline
Old 01-25-2013 | 06:38 PM
yea Mercury Racing tech support kinda paused when i asked if i should replace them.... like i was crazy or something but i thought it was a good question.... they said they will be fine.. im just glad you can now call in and actually talk to someone about the blue engines.
Old 01-26-2013 | 07:58 AM
Smitty's Avatar
Replace them now !!! Nuff said !!!
Smitty is offline
