Best 4 blade islander >
Old 01-25-2013 | 06:22 PM
Default Best 4 blade islander
Looking to buy a 4 blade prop for a 202 islander with 5.0 260hp. Boat has a 23p alpha mirage that came with the boat. Boat runs 62 with current prop at 5k rpms but is slow on plane and purposes a lot. I'm thinking maybe a 24p 4 blade may help. Willing to sacrifice a little speed for a better ride without hitting rev limiter. Any suggestions?
uptick is offline
Old 01-26-2013 | 05:52 PM
Give BBlades a call, they can help you get dialed in. They're doing some work on one of my props now.
http://bblades.com/
Just4FunII is offline
Old 01-28-2013 | 09:07 PM
Default BBlades
I would second that....BBlades helped me out several times, good folks!
Bad Bird is offline
Old 01-28-2013 | 11:05 PM
24 will be to much.. start with a 22 and then fine tune it after you have tested it!!! Remember accurate information is key when your labbing the prop..
fleg1 is offline
