Whipple upgrades on 700 merc >
Old 01-26-2013 | 08:39 AM
Default Whipple upgrades on 700 merc
I'm contemplating doing the whipple upgrades on my 700s . I would like to hear from members that have done these mods on the Good ,the bad and the ugly .
whataride is offline
Old 01-26-2013 | 03:56 PM
Just wondering, why not consider a twin turbo kit? I'm swapping from blowers to turbos because; it's cheaper in the long run, won't raise under hatch temps, and gets more power to the prop with less wear and tear on the motors.
Just curious.
Precision is offline
Old 01-26-2013 | 04:00 PM
Just curious.
What are you doing for a turbo setup ? in what boat ?
575cat is offline
Old 01-26-2013 | 06:48 PM
A Whipple upgrade is a couple grand, I'm sure a twin turbo setup is a lot more than that.
soggy bottom is offline
Old 01-26-2013 | 07:17 PM
Just curious.
Id like to see how that works.
Let us in on that project.
MILD THUNDER is offline
Old 01-26-2013 | 07:20 PM
Default fixx
Just curious.
heres your sign!...
FIXX is offline
Old 01-27-2013 | 10:11 AM
Just curious.
having a Twin turbo would be like getting the oil changed on the space shuttle in my area . The boat is a wide load and the nearest dealer that has the technology to service mercs ( properly ) is Double R and they are 4 hrs drive . I want to stick with something that is familiar to the avaerage mechanic .
Old 01-27-2013 | 01:04 PM
It's a full kit that takes my 525SC's to twin turbo EFI motors. With the cost of the kit, less what I can get out of my CMI E tops tails, and all of the blower parts each kit should only run me $2,500 out of pocket. That's why I thought this might be a good idea for the OP due to the kind of capital that selling the OEM parts could bring in the aftermarket.
The best part is I am getting away from the tedious maintenance requirements of changing oil on the 177's and the Gen V fuel pump housing. The shop that's supplying the kit and doing the dyno tuning really did thier homework to make this an easy bolt on kit.
I'll have the shop get me the dyno sheets for the stock 525's and also with the turbo kits for comparison.
Old 01-27-2013 | 01:18 PM
I saw somewhere these EFI turbo kits are about 12-13k each from Carson Brummet in California. Unless im missing something??
36-39k dollars for new blower systems (triple engine)
525SC blowers with carbs, intakes, pulleys 2000 each used=6k
CMI headers used=1500 pair x 3= 4500 bucks
So, if you can pull 10k out of your existing parts (not easy sell btw), your still looking at 25-30g to upgrade to turbo kits? The stock 525SC bottom ends will be borderline strong enough to support 700HP, maybe 750hp.
If it were me, I'd bolt some 8-71's on, run 7lbs of boost, and be done. The whole upgrade might cost you 5-6k after you sell the stock 525sc stuff. Changing the oil in my blowers takes me 30 minutes and 20 bucks once a season.
Old 01-27-2013 | 01:41 PM
Sorry I didn't elaborate on the supplier, I didn't buy the Carson kit. This is a new kit that has yet to hit the open market. Total cost of the kit is $ 8,500.00. Like I said the company that has put this kit together really did their homework. It's utilizing GT35 turbos and can support 1,000HP. The higher HP kit (utilizing GT45's) they have which is a few more dollars can support 2,000HP.
