Formula 242...looking
I am in the market for a 242. I love the look of the 86, but open to newer. Not looking to restore. I want a real clean one. I see one for sale, an 88 that says redone by Metan. Is it worth the extra money? Any help locating one will be greatly appreciated thanks!
http://oklahomacity.craigslist.org/boa/3695294812.html
Well with any older boat you can have problems most start with not being maintained. A good survey will help it will tell you if the engine has good compression, to telling you if the transom is wet.
These are great boats not the fastest but well built solid hulls. The hull is a 24 degree some of the Baja`s and others will have 22 degree hull and most likely a higher x dimension will make it a little faster.
Go take a ride and find out. The last two Craigslist postings look very nice. Good luck on your hunt also check out the Formula section you may find more info.
