454 chevy complete 330 hp
I have two low hour complete 454 gen 6 330hp marine power engines that came factory with edelbrock performer intake and #9015 750 holley carb also came with 12 qt dooley oil pan,closed cooling sytem and dual remote oil filters.They are complete right down to the marine wire harness, motor mts ,bellhousing, every thing to drop in and go. Oil pressue at idle was 55lbs and the compression was as follows 1-135 2-125 3-135 4-135 5-135 6-135 7-135 8-140 on one the other is 1-125 2-125 3-120 4-120 5-125 6-125 7-125 8-130 these are very clean engines. $2750.00 each. obo. I am new at this and i guess i need to figure the picture thing out but it appears that i can email pictures so email or call 541 821 0068 also i can deliver to a local freight co.
Hate to break it to you but 330 are not with much at all. Cast rotating assembly most 2 bolt mains no parts worth anything one them heads are just peanut port pulley the close system pans and carbs scrap the rest. Plus your new to the board. No harm ment just say
its a gen 6 motor, the heads are not peanut ports, they are 4 bolt mains and have stock roller cams in them. the L98 heads are actually said to be one of the better stock heads ever made. i upgraded mine to around 450hp with cam, intake, carb and exhaust. most people overlook them as junk, look again and you will see that they are very different from the gen 4 and 5 330hp. i have even seen these motors with pro chargers in the past that had held up at least a few years when i had seen them, low boost but they still had boost on them
you may want to try selling these on craigslist or ebay. i replaced a L29 long block, which is what these are, in my dads 99 rinker a few years back, 3500 for the long block and i sure would have rather seen him pay 2750 for a complete drop in. performance guys may not want them but a guy with a cracked or worn out stock motor looking for a stock replacement would pay that easy
Thanks guys they are 4 bolts with roller cams sold both to a guy in montana for a jet boat application good buy for him love your site rerigging a 257 carrera with a new dart 540 and xr outdrive and a Bob madera camshaft that i found out about on this site lots of help thanks for the replys
