Vinyl dye by VHT
Old 01-28-2013 | 05:55 PM
Default Vinyl dye by VHT
Any one try this stuff? I have a vinyl steering wheel that I am trying to get to match my carpet/paint...thinking about trying some of this stuff...
http://www.amazon.com/VHT-SP962-Viny.../dp/B00296D22Q
tnc110 is offline
Old 01-28-2013 | 07:50 PM
glassdave's Avatar
Neno the mind boggler
Its ok but in the end it is still a superficial product. Steering wheel is a pretty high wear item and even properly dyed and sealed has trouble holding up. VHT will look ok for a couple months but when it starts to go it looks bad, worse the a worn oem
08 OPA High Points Champion
glassdave is offline
Old 01-28-2013 | 07:57 PM
I second glassdave. I've used it in an automotive application and it definitely didn't hold up. The person who owned my boat before me used it on some of the sunpad and it would come off on your skin before we redid it. Sounds like the perfect solution it just didn't pan out. Plus like was said a steering wheel is pretty high wear. Sorry man.
mickeymcclgn is offline
Old 01-29-2013 | 08:12 AM
scarabman's Avatar
Are there any products like this that actually hold up well? What about professional type applications of vinyl dyes?
scarabman is offline
Old 01-29-2013 | 08:57 AM
h2oboater's Avatar
I used orange rattle can interior paint from Heart Beat City by OER. I used it to touch up the original 1974 rear seat on my Donzi Doral. It looks good & after one summer,, it held up well.
http://www.heartbeatcitycamaro.com/store/search.asp
h2oboater is offline
Old 01-29-2013 | 09:02 AM
johnnyboatman's Avatar
Like in everything its in the prep, no you just dont spray it on, clean the area well, then spray it with bulldog then spray it works good on soft wynil, if its hard then it can be tricky to get it to stick, remember, clean, bulldog, the spray
johnnyboatman is offline
Old 01-29-2013 | 09:09 AM
Wouldn't recommen it. Used it on seats before. Looks so fresh & clean at first but doesn't hold up well and in the sun when it warmed up it always felt like a gooey scab.
scarab63 is offline
Old 01-29-2013 | 12:03 PM
Stormrider's Avatar
JC Performance Engines
Why not just a new steering wheel?
Stormrider is offline
Old 01-29-2013 | 07:31 PM
h2oboater's Avatar
You are right prep is everything, & yes use the Bull Dog. I did not have soft spots or goo, held up well in the very hot summer we had last year. I'm sure it will wear, & a steering wheel may not be the best place to use it.
Old 01-29-2013 | 09:22 PM
yes mine was on the seats steering wheel may not be a good ideal
